rock krawler X-Factor kit - front bump stop install
AgentRice
Jeremy
Sarasota FL
2020 Wrangler Sport
Fire Fighter Paramedic
any tips on how to tighten this sucker?????
I can't get a wrench in high enough to hold down the nut
Roky
Roky
It’s tricky with the spring in. I use an open end wrench on an angle to hold the nut while using ratchet with Allen socket to tighten from the top. I jack up the frame to spread the spring enough to get ratchet in. I go at an angle from the front on driver’s side and from the back of axle on the passenger side. It also helps having the tire off so you can get up in it, and get-r-done........:)
