Right Drift after Steering TSB
dirtdigr
Bill
Oahu
2024 Willys
weird. Anyone know what the torque spec is?
So I finally got around to checking the torque on all the bolts after the TSB was complete. I found everything was not even close to torque spec's, especially the sector shaft/pitman arm nut . After I torqued the sector shaft nut(184 foot pounds), re-installed the track bar, and took a ride, I found my steering wheel is no longer centered. Would this mean that the dealership doing the TSB did an alignment while all the components were loose? Did I mess up the alignment by torqueing the sector shaft? Not sure what to do here.....any suggestions?
sam0329
Sam
Edmonton AB
2019 Unlimited Rubicon
Because the dealership has to take the nut out to replace the steeling gear box. So there is a chance the tech forgot to torque it back to spec. The torque spec on that 42mm nut is 184 ft-lb.
