Replace 2020 Rubicon Bottom Driver's Seat Cushion?
Parker81
Boston, MA
Hoping someone can point me in the right direction, or just tell me I'm crazy to try it and better off paying the dealer.
I have a pretty bad tear in the bottom cushion of the driver's seat of my 2020 Rubicon Unlimited. I figured I could buy an OEM replacement and DIY it, but I can't seem to find any instructions on how to do this online. From what I was able to find, it seems like this is a fairly involved process. I'm pretty mechanically inclined, and do a lot my own maintenance, but I wanted to see a set of instrucitons/YouTube video to see what I was getting into before buying the replacement part.
Has anyone here done this themselves/know where I could find instructions?
I talked to two dealers to see if I could get it replaced under warranty, but both are labeling it "wear and tear" and quoting me about $700 to replace it. (Side note: I'm a little annoyed because I have the Mopar "Maximum Care" extended warranty and they're still saying it's not covered, but that's probably for a different thread.)
For reference, this is the part that I need to install: https://www.autonationparts.com/parts/mopar-front-seat-cushion-cover-left-6pw86vt9af
Any help/suggestions are much appreciated - Thanks
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I'll DM you the procedure.
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
Just so you know. If you take it to a local upholstery place. They can do it way cheaper. They may even be able to repair your seat or build you a ne replacement cover.
Also just know I paid a local to me upholstery place $700 and they took all the factory foam out and rebuilt both front seats with the most gel memory foam they could fit into the stock seat covering. It made a huge difference. My Jeep is 16 to 20 hour multi day runs comfortable.
Parker81
Boston, MA
Thanks - that's a good point - I'll check in with a few auto upholstery places nearby.
Resin Addict
Randy
Ada, Michigan
‘22 HighTide, ‘59 Chevy Apache, ‘32 Ford Coupe, ‘22 Hyundai Tucson
Custom painter/freelance artist
If you’re mechanically inclined, you can do it yourself…by a hog ring pliers and a bag of hog rings on Amazon, watch a YouTube video where a guy does exactly what you want to do, and you can get it done in about 2 hours.
I replaced an entire interior with OEM leather…it’s actually not that difficult.
if you have any questions send me a PM.
