Relocating cargo 12 volt
Dlit
South Florida
Rubicon JL Recon
Anybody relocate this receptacle to a better location where you will not have problems if cargo shifts? Any ideas or pics?
Thanks,
Dlit
Dlit
South Florida
Rubicon JL Recon
Having trouble sifting thru all this info
RicRecon
Ric
NorCal
2021 JLUR 3.0, 2021 JT Overland 3.0
Jeep Wrangler JL Relocating cargo 12 volt IMG_4936
I relocated mine to the front of the roll bar area because I didn’t like cargo hitting the plug. Just used a 12v plug extender cable behind the plastic. Added a plastic plug from hardware storeto fill the original hole.
Dlit
Dlit
South Florida
Rubicon JL Recon
Haven’t pulled the panel yet, does the 12 volt plug have a wire harness that you just unplug? I bought a marine grade 12 volt which also has a on off switch and 2 usb in a second plug with the same form factor in series. Was planning on mounting them in front under the seat belt. RicRecon when you say 12 volt extender cable can you elaborate? Thanks
Left Field
Tim
Western WA
'67 RS-SS Camaro, 2021 JLUR392
Thanks,
I added a 12V outlet in about the same location as @RicRecon (picture below), but added a new 12V wire from the battery and left the factory outlet alone. The space behind that panel is fairly tight so not a lot of location options.
You'll note in the picture below I'm using a low profile right-angle 12V plug. That might be a solution for the original outlet location.
LF
Jeep Wrangler JL Relocating cargo 12 volt 1726803327376-0a
RicRecon
Ric
NorCal
LF
Nice. Did you fabricate that mount yourself or buy that somewhere? I’m trying to figure out a mount in that same location for a portable solar generator to be securely mounted.
RicRecon
Ric
NorCal
I initially expected to cut and splice wires but ended up finding a short cable with male in one end, female mount on the other so I just securely plugged together and route the cable around the roll bar mount. Figured if that didn’t work, I would splice. I’ll try and find what I ordered off Amazon but it was easy to find on there.
Terrymo
Terry
2023 JLURXR 3.6 ET
Even though the installation instruction show it for the dash, the rear cargo outlet is the same
https://www.quadratec.com/sites/default/files/installation_instructions/Q_JK-JL_12v_HARNESS_12999_3183_LTR (2).pdf
Left Field
Tim
Western WA
A little home garage fabrication work, folded sheet metal and attached to the fender tub with 4 stainless nutserts. Turned out rock solid; might upsize it eventually to a larger battery as there is plenty of room.
Dlit
Dlit
South Florida
Rubicon JL Recon
linux_guy
Alabama
2020 JL 6-speed manual, 2011 Compass 5-speed manual
Depending on use case, I'd be tempted to use Noco jump start box I have. It's always with me, and I'd be concerned about doing any interior electrical mod perfectly. I would probably drool over the end result of the craftsman-lile work I will read bout here though. If I was convinced I could do similar, I wouldn't mention this workaround.
Dlit
Dlit
South Florida
Rubicon JL Recon
Depending on use case, I'd be tempted to use Noco jump start box I have. It's lways with me, and I'd be concerned about doing any interior electrical mod perfectly. I would probably drool over the end result of the craftsman-lile work I will read bout here though. If I was convinced I could do similar, I wouldn't mention this workaround.
Ya I will do lots of research before any elec work. Will avoid splicing with finicky computers on the jeep….would rather run additional wire.
linux_guy
Alabama
That low profile 90 degree adapter 12V adapter that @Left Field mentioned could push me over the edge. Thanks for making me buy that. If I was glamping or otherwise needed crazy amounts of power, my Noco 4250 A and Ego POWER+ Nexus Portable Power Station would be summoned. The Ego holds four lawn mower batteries. The Ego has a solar panel adapter for my solar panel. Had enough lawn mower batteries accumulated that I found myself needing it.
Not why I did it, but sliding windows locking at about every 1.5 inches could keep the pricier bits securely locked while passing the solar connector end into the interior.
Jeep Wrangler JL Relocating cargo 12 volt KIMG0008_1.JPG7637690025901022841
Via the guards, I could keep things somewhat secure and pass the Ego solar controller through a slot.
Jeep Wrangler JL Relocating cargo 12 volt KIMG0025.JPG7665519726319381994
