Slow your roll
Does anyone know how to access the wiring that feeds the 12v plug in the cargo area of the JLU? I’d like to tap into it to add a switch to control LED lights.
Just pull the side panel off, splice into the wires, and run the wires to the front, under the carpet, or along the side floor plastics. Then add a switch or toggle wherever. Easy to do, ive done this with several vehicles, in the past. Same theory. No diagrams needed. Now, if you decide to go the fuse box route, that's a little more difficult. I prefer running straight from the battery post, for the ease of it. Not the cleanest, but the easiest, and you always have power. I also like lighted switches, so you wont forget the accessories are turned on.Does anyone know how to access the wiring that feeds the 12v plug in the cargo area of the JLU? I’d like to tap into it to add a switch to control LED lights.
Can you please share a picture of the pliers or more how to pics? Thanks!I pulled out that lighter socket when I tapped into it for the 12 volt power for my trailer wiring...I did not pull the panel off...If you look inside the lighter socket you will see two square hole directly opposite each other...I have a special pair of pliers the have two tits sticking out both sides that fit perfectly into the two square holes...Insert plier tips into square holes and pull straight out and presto, the socket and wiring pulls out.
The only thing that holds the lighter socket in the panes is a plastic/rubber grommet...
