Red Dash Trim Removal / Replacement
Bkenyon53
MA
2010 Camaro SS; 2016 JKU; 1971 VW Beetle
I’ve seen a video showing how to remove the radio but has anybody found one showing a step-by-step on how to remove the dash (the red area).
My buddy said he’d paint it for me if I just dropped off the dash but I’m sure these pieces come off sequentially.
Code IV
Ron
Richmond Texas
2018 JL 2009 JK
Owner Mojo Shades
***********SAFETY NOTE************** DISCONNECT THE BATTERY AND LET SIT FOR 30 MINS BEFORE YOU PULL THE AIRBAG*******
You need to pop off (has clips only) the AC controls bezel. Unplug the AC controls and starter button. The remove the radio bezel (Again clips only). Next remove the top dash pad. This has several clips and one screw that is hidden under the radio bezel. Now the fun part. Remove all the top screws on the driver's side dash (Red piece). The pry off slowly (Clips on the bottom). The passenger side is harder. Remove the top screws. Under the bezel is the SRS Airbag trim piece. You will need to remove that (3 clips) and cut the zip tie. Now remove the two screws that are under that trim piece. Open and drop the glove box. Look up and you will find two bolts (see picture) Those are for the airbag. (the airbag will come out with the dash panel. (The red thing you want painted). Remove the two bolts. Once you remove the bolts, pull the airbag and dash bezel towards you. from under the dash, you will now see a yellow plug. Unplug that plug and you are done!
Jeep Wrangler JL Red Dash Trim Removal / Replacement Dash with top off drivers
Jeep Wrangler JL Red Dash Trim Removal / Replacement Dash removal1
Jeep Wrangler JL Red Dash Trim Removal / Replacement Dash removal2
Jeep Wrangler JL Red Dash Trim Removal / Replacement 37008567_2005219066195843_7230994612989460480_n
Jeep Wrangler JL Red Dash Trim Removal / Replacement 37056218_2006436726074077_6888227111480328192_n
Jeep Wrangler JL Red Dash Trim Removal / Replacement 36976808_2006436642740752_2530253255133364224_n
Jeep Wrangler JL Red Dash Trim Removal / Replacement 37167426_2006436719407411_3722834865708597248_n
Jeep Wrangler JL Red Dash Trim Removal / Replacement 37124598_2006436646074085_3234320883120078848_n
Bkenyon53
MA
Whoa...THANK YOU!
Not including the 30 minutes after the battery disconnect, how long did it take to actually remove the trim?
Chocolate Thunder
Jeremy
It's a wrap
I appears to have been done by a pro. Is that you or did you have it done? If so where and how much, if you don’t mind sharing.
Code IV
Ron
Richmond Texas
2018 JL 2009 JK
Owner Mojo Shades
Chocolate Thunder
Jeremy
Code IV
Ron
Richmond Texas
2018 JL 2009 JK
Owner Mojo Shades
I saw that your workspace looks like a pro shop of some kind. Great job. So how much will it cost me for you to wrap mine?
You can do it yourself. It's not that hard. Just follow the instructions from the link I posted and then take the pieces to a local shop that does wraps. If you are in the Katy/Houston area I would suggest 5S Signs to wrap the pieces.
Bkenyon53
MA
It's a wrap
Phenomenal job!
It really is the way it should’ve looked from the factory
EDIT: Did the airbag light turn on after you disconnected it? If so, did you need to take it back to the dealer to have it turned off?
Code IV
Ron
Richmond Texas
2018 JL 2009 JK
Owner Mojo Shades
Phenomenal job!
The light came on but after I put it back together, it went out. Thanks! pretty proud of this!
mango315
mark
new york
2018 jeep wrangler rubicon 2dr
here are some pics of a successful trim swap thanks to this forum...Pic18 was driving by my area and was nice enough to do all the work since I didn't trust myself...so if he sees this he can comment better on the difficulty...
I'm very happy with the grey panels with my stingray grey exterior
Jeep Wrangler JL Red Dash Trim Removal / Replacement IMG_0806
Jeep Wrangler JL Red Dash Trim Removal / Replacement IMG_0805
Pic18
RI
2018 Mojito JLUR, 2017 Grand Cherokee Trailhawk (my wife’s)
Thank you @codeIV for the great instructions on how to do the removal. Thank you @mango315 for doing the swap with me. Without further ado, I present a Mojito JL with red dash inserts.
I think I may need some time to determine if I like it or not. The red and green both compete for attention.
Jeep Wrangler JL Red Dash Trim Removal / Replacement CC2A2B28-EBA5-40FB-A9FC-56447D3ED220
Jeep Wrangler JL Red Dash Trim Removal / Replacement 50564045-32F1-4C4A-87A0-DA3D8AA950DD
tnjrb
2018 Punk'n JL Rubi
It's like Christmas time in your Jeep!
