Rear View Camera Washer Nozzle idea
Cloud 9
oIIIIIIo 2022 Jeep JL 392 1972 VW Beetle
Howdy, I don't post much but I've found lots of helpful ideas on this forum so I figure I would share how I added a sprayer to my rear (backup) camera if someone might be interested. One thing I've noticed after owning my Jeep JL for a few winters is just how dirty and hard to see the backup camera image gets with all the dust, dirt, and road salt. So, I wondered if there was a way to add a washer nozzle to my rear view camera. ? Well after doing a little tinkering on it and testing out the results for the past few months, the answer is Yes. Here is what I came up with if someone wants to do something similar.
Jeep Wrangler JL Rear View Camera Washer Nozzle idea Screen Shot 2024-03-27 at 2.07.53 AM
I figured out that on my Jeep the windshield washer system has 2 separate pumps, one for the windshield and one for the rear glass (and forward camera sprayer installed at the factory). I decided to tap into the hose that runs to the rear glass just upstream of the quick disconnect connections that go up to the hard top. I chose to use a ¼ Outside Diameter Push connect T-fitting because they are super easy to connect and disconnect. However, to get it to fit I did have to sand down the factory hose a wee bit to be able to plug it into the slightly smaller ¼" OD T-fitting. This is definitely a pain but to me it was well worth it to run all connection using ¼ push connect fittings.
Jeep Wrangler JL Rear View Camera Washer Nozzle idea IMG_0545
From there I ran ¼" OD (⅛" ID) kink free silicone tubing down the drivers side of the cargo area, across the inside of the car jack storage cubby then up to the fabric sleeve that connects the wire harness from the cargo area to the tailgate. The pinch point created when closing the tailgate was the biggest obstacle to this project. To prevent the hose from kinking when the tailgate is shut I added a spring inside the factory sleeve to allow a slight curve to be maintained even when fully closed.
Jeep Wrangler JL Rear View Camera Washer Nozzle idea IMG_0541
I also modified the tailgate panel by creating a cutout to allow the wire sleeve to enter a bit farther away from the hinge, this combined with using silicone tubing helped a lot with preventing the hose from getting pinched and cutting off fluid flow. I'm planning on eventually adding a tailgate table like those from Goose or AAL and they use this same cutout design. I ran the silicone tubing across the tailgate to where the camera and 3rd brake light wires have quick disconnects. There I added a 1-way check valve and quick disconnect L fitting allowing the tire carrier to be completely removed if needed. The check valve is important to keep fluid near the rear camera sprayer which sprays instantly without any delay.
Jeep Wrangler JL Rear View Camera Washer Nozzle idea Screen Shot 2024-03-27 at 2.04.01 AM
I then switched over from silicone to nylon ¼" OD air brake tubing and ran that through the grommet on the tailgate to keep everything nice and weathertight. I covered both the wires and tubing in a braided cable sleeve and ran it to the tire career to keep it looking like it came that way from the factory.
Jeep Wrangler JL Rear View Camera Washer Nozzle idea Screen Shot 2024-03-27 at 1.42.32 AM
In order to run the hose in a way that would not interfere with pulling off the spare tire, I routed it inside camera housing and out though a hole in the bottom. The tube has some slack so it can be pulled out or pushed in as needed.
Jeep Wrangler JL Rear View Camera Washer Nozzle idea Screen Shot 2024-03-27 at 1.48.00 AM-2
I modified the rear tire camera cover by removing the locking mechanism and adding a sprayer (same one used on the back lift gate glass.) The angle of this sprayer is just about perfect and it's Mopar so that's makes it an OEM option that I am sure Jeep would charge $799 for ;). To the sprayer I connected a ¼" pneumatic push connect L-fitting. This lets me easily remove the camera cover/sprayer anytime I need to access the spare tire. I'm thinking about upgrading to the TeraFlex Alpha hinge and mount and I feel confident this could be even better integrated into that setup.
Jeep Wrangler JL Rear View Camera Washer Nozzle idea Screen Shot 2024-03-27 at 1.05.29 AM
In the end I'm happy with the way it turned out. It turned out nice and clean and kinda OEM looking. Being able to quickly clean the rear camera when backing up has had a dramatic impact on camera image quality (plus it's cool to see the water spraying the camera :) ). I've been running it all winter and it's worked very well, it was a bit of work to setup but I find I use it all the time now.
Jeep Wrangler JL Rear View Camera Washer Nozzle idea Screen Shot 2024-03-27 at 1.53.53 AM
I figure i would post this little camera washer mod on here just in case it might be useful to someone else. I've been slowly upgrading my Jeep with helpful little things like backseat heaters, hood struts, key fob controlled hood latch, and now a rear view camera washer nozzle to make up for some of the little stuff Jeep forgot to install at the factory in Toledo. Kinda like that old Johnny Cash song, I building my Jeep "one piece at a time". ✌?
rohdawg
Long Island, New York
Merchant Marine
Outstanding project and great write-up!
Like you said, “Great success!”
BDinTX
Dallas, Tx
Impressive!
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Wow, bravo and great write up.
roojacksid
Ron
Austin, TX
2022 Bright White JL Rubicon
Very cool. I just periodically wipe it off with a rag, paper towel, or my finger.
hammten
WI
2021 PBJ JLUR 4xe
Awesome mod! I love the cleanliness of the modification to make it look as OEM as possible. Considering you had to run the silicone tubing through the locking mechanism area of the back-up camera bezel, do you have any problems with the bezel loosening off the stock tire carrier? Or did you do anything to prevent the bezel from falling off the tire carrier?
Once again, congrats on the awesome modification!
Ridergda
Jimmy
BC
2021JL diesel
Hi OP, i got everything else finished but i am not sure which ¼" pneumatic push connect L-fitting that could push in to washer nozzle , could you please point me the correct L fitting for the mod?
Ridergda
Jimmy
BC
2021JL diesel
I finished my mod finally,
I run the T /Y near the rear window nozzle,make the process much easier.
Happy with the result!
Jeep Wrangler JL Rear View Camera Washer Nozzle idea 1000320521
Jeep Wrangler JL Rear View Camera Washer Nozzle idea 1000320525
21JLURDG
Bill
Olympia, WA
2021 Wrangler Unlimited Rubicon 3.0 Gecko
Great write-up. Do you find the water drops obstructing the view? I disconnected my front camera sprayer because the water drops caused more problems than dust on the trail.
