Rear Track bar adjustment
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
Hello, i know there is posts or videos about how to adjust the rear track bar, can someone chime in please ?
I am aware that in order to move the rear axle/frame a ratchet strap needs to be used, but where do i hook it up ?
Thanks
Deleted member 64316
Guest
I like to put a jack on the frame rail and just raise the frame until the holes line up for you. Then you don’t have to give away beer to a stranger ?
AC77
AC77
AC Abegian
Los Angeles
im attempting to adjust the rear track bar to center the rear axle , with an adjustable bar
jadmt
jeff
montana
measure how much it is off side to side and divide that by half as your starting point. then as was said when you go to put it in have someone push on the side of your jeep. if you use a ratchet hook it to the frame and to the axle ie lower shock mount and upper frame by bumper. are you using a raised track bar mount?
Roky
Roky
Thanks
I don’t use ratchet straps, I just lay on my back and push the frame over with my feet….
AC77
AC77
AC Abegian
Los Angeles
no , im not,
jadmt
jeff
montana
AC77
AC77
AC Abegian
Los Angeles
depending on your lift they are a good idea. if not lifting much no big deal.
mopar 2" lift, which came out to be a bit more, but not more than 3" , i bought the front and rear JKS track bars together , prior to the lift
roaniecowpony
Retired Engineer
You don’t have to use a ratchet strap normally. Offer someone walking by a beer and have them push on the side of the Jeep.
Usually, my wife wants more "payment" than a beer, if you know what I mean.
jadmt
jeff
montana
at 3" i would invest in a raised track bar bracket. it is one of those things that once you have one you feel the difference if you dive fast on road
roaniecowpony
Retired Engineer
Or do whatever your wife wants you to do...
