Rear locker stuck
JINO
Jino
Socal
2021 jlurd
Went wheeling a few days ago, and noticed the light blinks, and will engage rear locker when im stopped at a light. It wont turn off.
Noticed no MPG loss, clicking noises, or binding.
How much damage is it doing?
Isn't this similar to lunchbox lockers?
I have about 1000 miles til 100,000, where the warranty ends i believe. That's last case scenario, I HATE going to the dealer.
flick2614
Randy
AZ
2021 Jeep JLU Rubicon Diesel
Is it actually engaged or just the common position sensor failure?
azjl#3
North AZ
pretty sure you would know locker is locked first turn on pavement.
JINO
JINO
Jino
Socal
2021 jlurd
I dont think its actually engaged. I've driven about 200 miles since then, and it feels normal.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Yeah, I'm going to go with locker sensor failure.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Also, I heard the cheapo ZLocker knockoffs from Amazon work.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
I saw that it was $133. So not too bad, easy fix?
Easy, but tedious. You have to pull the cover then one of the carrier bearing cap bolts. Then it's a small screw to remove it. I believe you get a pack of several sensors and have to manually try them out until you find the one that works. That's the tedious part.
Then absolutely do this: https://www.jlwranglerforums.com/forum/threads/locker-position-sensor-potting-dana-44.59581/
Once you get the sensor back in, replace the bolt on the carrier bearing cap and be 100% certain you torque it properly. Then replace the cover and fill.
Or use the sensor bypass harness. That is a ton easier.
yokramer
Snark Incarnate
Arent the new ones potted from the factory? 100% still should put dielectric grease in the connector tho.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
I dunno. Maybe.
JINO
JINO
Jino
Socal
2021 jlurd
Oof, that's far from easy.
Terrymo
Terry
2023 JLURXR 3.6 ET
It sounds tricky but if I did it you can do it. @chevymitchell can walk you through it if the link to the instructions I posted don’t make sense. I potted mine but carry the z-automotive bypass off-road just in case.
