Rear differential Skids
ZeroJL
Daniel
Louisiana
2023 JLURX
I just added the Artec C gusset to the rear axle. I was running the Metal Cloak rear differential skid, but it will not fit w the C gusset. With the Metal Cloak diff cover, the bolts are recessed. Question...should I run without a rear diff skid or should I replace the diff cover and get another skid that will work with the gusset in place?
CarbonSteel
??? You mean the front axle? The rear does not have "C's".
Both my front and rear were fully trussed, with gussets on the front, and control arm skids on both and none of that would interfere with a differential skid plate.
Photos?
kah.mun.rah
Merenkahre Jr.
Duat
I think you mean a rear truss.
This:
Jeep Wrangler JL Rear differential Skids 1696741111979
mixed with this?
Jeep Wrangler JL Rear differential Skids 1696741140427
I can see where the brackets would be an issue.
If you want a rear diff skid the one by Rancho should work with the truss:
Jeep Wrangler JL Rear differential Skids 1696741244664
ZeroJL
ZeroJL
Daniel
Louisiana
2023 JLURX
Yes..my apologies. The rear axle truss.
Jeep Wrangler JL Rear differential Skids 20231007_161415
Jeep Wrangler JL Rear differential Skids 20231006_173312
ZeroJL
ZeroJL
Daniel
Louisiana
2023 JLURX
And yes..with the current skid plate system I have, it doesn't work.
I see some people NOT running rear diff skids. I'm just wondering if the axle housing is strong enough to take a beating or if I should get a different diff cover and get another skid plate.
CarbonSteel
Next Venture skids are the strongest out there and protect the pinion area as well.
I have a full set with covers for sale in the marketplace. They work perfectly with trusses.
kah.mun.rah
Merenkahre Jr.
Duat
IMO a diff skid is more of glide plate than in impact plate, helping the diff to slide over obstacles rather than catching a lip or edge of the diff or diff cover when slow rock crawling. If you are planning on high impact to your diff, you might need to protect more than just the pumpkin.
pmarold21
Paul
Memphis
2022 Jeep Wrangler 4xe Rubicon (Gobi)
I just did the Badge of Honor trails in Hot Springs with the DV8 rear diff skid plate. Seemed to work really well (although we didn’t hit it hard) plus it protects the axle some. Take a look at that one based on your comments.
ZeroJL
ZeroJL
Daniel
Louisiana
2023 JLURX
Unfortunately it won't work with an axle truss. Think I'll be fabricating something.
c20040215
Leon
Rough country is another option to consider.
In my personal experience, it is cheap, strong, no interference issue, and it protects the rear pinion.
Cons: may not work with other diff covers.
Jeep Wrangler JL Rear differential Skids PXL_20230825_204203997
