Random coolant temp spike
namrebo
Eugene Ernest
Pennsylvania
2021 Wrangler
Pipefitter Journeyman
Yesterday I was sitting at a red light (which was godly long, maybe around5 mins) AC on was in drive. Got the beep, and looked down at cluster at it was at 249. As soon as I moved it went down, and I can see the gauge the actual analog one kinda jumping around. Tested it again then on a backroad stopping waiting 5 mins both AC on and off…nothing…
Driving it later in the gauge did seem to kinda bounce around again but never got that hot
any ideas?
Most recent thing I did was remove grill to install a new winch and remove old. Same winch so not like the profile is blocking the airflow.
Thanks
namrebo
namrebo
Eugene Ernest
Pennsylvania
2021 Wrangler
For reference fan was running in “jet engine mode” and temp was not dropping. Was it actually overheating or could sensor be messed up?
namrebo
namrebo
Eugene Ernest
Pennsylvania
2021 Wrangler
I didn’t check much as I don’t drive the vehicle every day. When I get home today from work, I’m going to do some digging.. after reading a bit online it seems like the plastic seem on that expansion tank is prone to failure
namrebo
namrebo
Eugene Ernest
Pennsylvania
2021 Wrangler
Cold engine, off since last night. Resivoir has no coolant in it. Can see it in the pipe at the bottom but none in actual tank
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
When was the last time you checked it? Definitely fill and monitor daily. Look for leaks at water pump, and at the T near the engine cover - assuming it is a 2.0. - of course check the black reservoir for leaks😜
namrebo
namrebo
Eugene Ernest
Pennsylvania
2021 Wrangler
To be honest. Never. I never had problems with any of my new vehicles. At least for a long long while. I’m going to fill it up and see if I can ID a leak. Nothing obvious right now that I can see.
Yes 2.0 sorry if I didn’t mention that.
Any recommendations for coolant?, There’s obviously some in the system already and it will be mixed.
Nokones
Kenny
Sun City West, AZ
23 Rubi, 21 Silverado, 13 Grand Sport, Cayman GTS,
Unemployed For The Rest Of My Life from a career of spreading love, cheer, and joy to lots of special individuals that were asking for attention..
Maybe you have an air pocket. Was your cooling system serviced recently? Some cooling systems require to be burped/bled after it was serviced and filled with coolant.
ScotM
Scot
Southern California
Use the premixed 90032 from mopar
Mopar 68163849AB 10 Year/150,000 Mile Coolant 50/50 Premixed - Embittered, 1 Gallon | Genuine 10 Year / 150,000 Mile Blend, OAT 50/50 Premixed, -34F to 265F, OEM Radiator Fluid for Jeep, Chrysler, Dodge, Ram https://a.co/d/08Ni1eIR
namrebo
namrebo
Eugene Ernest
Pennsylvania
2021 Wrangler
No not serviced since water pump bolt recall thing in like 2022
