Rancho Geo Brackets Middle vs Top Hole
Kum4224
Kumail
Los Angeles, CA
2018 JLU Sport
Anyone with lifted Jeeps on here running rancho geo brackets and stock LCAs and UCAs mounted to the middle hole?
How does the Jeep ride and what were your caster numbers?
I am 6 deg with the UCAs on the top hole but I'm still getting a good amount of steering wander at fast speeds on the highway. Especially the hilly and windy freeways here in SoCal.
Thinking of moving to the middle hole but it'll probably put me at 7 deg.
GaryToo
Gary
S Jersey
22 JT
Retired Operating Engineer Local 825
OE control arm bushings alone are the reason i initially replaced lower front control arms. Same reason for track bar swap. I use synergy front track bar now and MetalCloak control arms and the synergy track bar/ sector shaft brace all played a part in removing the wandering on my 22 JT. It takes a lot of parts to add up to getting the wander as good as you can get and the steering as tight as can be. It all contributes to more enjoyable trip down the road. I still only have 16000 highway miles so it was not worn out parts I replaced
