Radiator options
_pointblake_
Blake
Montana
im around 70k miles on my 2022 392 and I've had some overheating concerns on trails and long mountain drives.
Currently adding the melling high flow oil pump, changing plugs and coil packs, and trying to upgrade the cooling system while I'm at it.
*My main question is if anyone knows of aftermarket radiator options that will fit in the pretty cramped engine bay?
Bayrat
DA
NY and Fl
2023 Rubicon 392 - 2024 Gladiator Sport BAREBONES
Following this
kefurr
D’Iberville MS
2021 Wrangler
@_pointblake_ check with some local parts stores looks like OSC offers one part #2957
@Bayrat looks like you split time between NY and FL
In NY looks like Fisher auto parts stocks it in their warehouse so store should be able to get it in a day. In FL looks like Original Equipment Inc stocks it in some of their stores.
Jeep Wrangler JL Radiator options IMG_3474
_pointblake_
Blake
Montana
emailed them and it wasn't a valid address. I found this one though that says it will fit
Jeep Wrangler JL Radiator options Screenshot_20250714_144551_DuckDuckGo
Bayrat
DA
NY and Fl
It sounds as though the radiator has the same specs as the manufacturer's but includes a larger radiator for the transmission.
danba
Johnny
Southwest
Look into the RPMExtreme fan controller as a better solution for your cooling woes. In my experience aftermarket radiators are worse, not better, than the OE.
The RPMExtreme will allow the fan to run at a lower temp threshold.
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
You got a link for this fan controller?
