Question on Rubicon Takeoffs
Smoke Showing
South Jersey
2018 JLU
Check for oil seepage on the shocks. speed bumps and potholes felt like I was hitting a curb. Ended up finding driver front and passenger rear were leaking. That was at 30k miles.
2upertf
2upertf
Wrightwood CA
2019 JLU 2.0 Billet Silver Metallic
Aerospace Engineering
2upertf
2upertf
Wrightwood CA
I have pretty much the same setup, the stock Rubi shocks are pretty soft vs. anything aftermarket, don't think the shock change would help w/ the ride characteristics you're after. Like others mentioned, getting those tire to a lower psi could make just the difference you're wanting.
I ended up w/ Fox 2.0 shocks and it's firmer still, but in a more controlled way, not as mushy. I have my tires about 30 psi FWIW.
At 30psi do you get the low pressure warning?
blnewt
New Mexico
Just ask @cosine he knows!
The Fixer
North Jersey
2018 Mojito! JLS, 2018 Firecracker JLUSS
Teacher
I do mostly just dirt roads but also some more gnarly trails. I haven't really aired down since it takes so long to add air again with my compressor. I usually run about 38psi. I haven't tried disconnecting the swaybar either. I have 285/70R17s mud terrain.
When I go over potholes the whole jeep shakes and rolls.
38 cold is gonna be close to 40-41 when warmed up on the road, which is too high for an M/T (IMO). I keep my BFG KO2s around 35-36 warmed up. From what I've read in other tire threads, M/Ts sometimes like even less than that.
From what I remember, the Low PSI warning turns on around 32 psi. Good luck!
Old Jeeper
Don
US Army Infantry, IT Engineer
I will see how it rides with a little less psi. I have 285/70R17s and usually run them at 38-40. If you run at 32 do you get the low pressure warning?
Yes but ignore till I get my tas r
