Question about 11.2.6 beta
Chocolate Thunder
Jeremy
Included in this firmware version
  • Adds Anchor Mode (Lock all 4 brakes and hold)
  • Press brake firmly and pull hi beam stalk. All 4 brakes will hold indefinitely until accelerator pressed. Works in conjunction with Winch and Cooldown modes as well
Does this feature work with the engine off? Helpful for mounting or rotating wheels.
Bearded_Dragon
FL
2018 Mojito! Rubicon
How would brake lock help change or rotate wheels vs being in park and/or parking brake on? Not being an asshole, just curious.
OldGuyNewJeep
Don
CT
My guess is no. It’s a live feature like winch mode that only works with the engine running.
Chocolate Thunder
Chocolate Thunder
Jeremy
Parking brake doesn’t help with the fronts. I’m getting older and not having the rotor spin as I try in vain to put a heavy tire on the studs would help me to get it placed on there easily on the first try.
LoganDzwon
Logan
SoFla
JLUR
Just put the t-case in 4L and then pull the handbrake.
Redbaron73
Ronnie
2020 sport s unlimited;2020 Rubicon Unlimited
I never thought of this solution, but you are so right. The dang turning is a pain in the arse.
One solution a friend shared with me seems to work pretty well. I have a mechanincs chair that is on rollers. Sitting in the chair, put the tire on my feet and use my feet to increase the height while placing it on the studs.
a slight rotation of the feet or a free hand to rotate the rotor helps.
