Any idea what this is about? JL Lite
GRAK
GRAK
Out West
JL Rubi, Corvette
10! Maybe I should pull it and update it, never bothered...
kobejo34
Stephen
Hoschton, Ga
19 JLUR
I dont think you can override it any lower then 20 or 25 and once it alarms you have to inflate pass that number again. but Im far from an expert. I've always had good luck with a PM to z auto.
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
This is correct, the Tazer cannot override the hard program set of 25#
Chocolate Thunder
Jeremy
I’ve also had tires show the same pressure but one shows red while others don’t. I have a suspicion (not confirmed) that even though the pressure display shows pounds in whole numbers, it actually registers more precise increments and rounds them to whole pound numbers. So even though your display shows 23 psi at each corner, there is some variance and this is why your front right shows as under inflated for the threshold you’ve set. Example:
23.2 — 22.6
23.0 — 23.4
All rounded to 23 on the display.
Suffolklou
Lou
Richland Wa
2020 JLUR
if it sees it as low, inflate it to turn it white, then deflate it and it will be white at 23 psi. The jeep lets the tire pressure go below the setpoint to account for pressure changes due to temperature or weather.
