I’d also look into getting a couple of Colby valve stems for an emergency. Look them up online. They can be installed without breaking down the tire. If you damaged a stem, you could replace it with one of these. You might have tpms bits rattling around, but would work until you could drive to a tire shop.
I considered removing as well, but It is problematic when you do need to have a spare with you, many organized clubs and runs require you to have a Spare and likely for good reason since sidewall issues are not repairable. I have a Tesla, Infinity Hard Top Convertible and 36' Motorhome none have a option for a spare so relying on Roadside service or tire repair is normal these days for us but off road i would NEVER consider it especially in the back country solo with no cell service or out of radio range to support. While if small enough cold fit in the back then you loose too much cargo capacity.
With that said I really like the no spare look
I believe the Gladiator's spare is underneath the bed.Just sayin.......![]()
Yeah, I realized that after I clipped the picture......oh well, can't win them all...I believe the Gladiator's spare is underneath the bed.![]()
I bet it was, I can tell a difference without all tools, recovery gear and arb cooler. Not sure what it weighs but enough to want taller or stiffer springs,I seriously doubt that it was faster and likely my imagination but it sure felt spunkier.
However, it did change the stance. The rear is definitely a bit higher that it was.
The stock scissor jack can handle 37" tire changes, lift kit has nothing to do with changing a tire.Decided that since my spare weighed almost 130 pounds and the likelihood that I would I would be able to wrestle it off of the Jeep, by myself, in the event of a flat time around town was virtually zero. And since the included scissor jack can't raise the Jeep high enough with the 2" inch lift kit and 37" tires to change a tire, I would be at the mercy of AAA and/or Uber in the event of a flat anyway.
