Pro Comp Wheels on Non Rubicons
MyJlU
TJ
The Ocean State
2018 JKU Sport
Sr Product Line Researcher
Looking to see Pro Comp Wheels on Non Rubicon JL's!!! Help me spend my money!!!!
Therby
Taylor
Ontario, Canada
2018 JL sport 2dr
Called the predator i think. They must be discontinued or will be because they keep getting cheaper and cheaper.
17x8.5 0offset 315/70r17
Painted the lip to match jeep
Jeep Wrangler JL Pro Comp Wheels on Non Rubicons F7F69CE1-8177-4B52-8CE2-EEC2615684ED
ChrispyJL
chris
Rockaway, NJ
2018 Punk"N JLU Sport s
Building Mechanic
I like the Rockwells a lot, however Pro Comp wheels are a bit on the heavy side @ 35 lbs.
Jeep Wrangler JL Pro Comp Wheels on Non Rubicons rockwells
MyJlU
MyJlU
TJ
The Ocean State
2018 JKU Sport
Great Start Keep It going!!!!
PadreFreddie
Alfredo Marrero
Vero Beach, FL
2019 Jeep Wrangler JL 2 door, 3.6 manual
Hey brother, I like the stance on your JL, do you have any type of lift kit? If you don't, do the 35's rub at all? Thanks!
bartscrc
Ryan
Cincinnati, Ohio
Punk'n JLU
Jeep Wrangler JL Pro Comp Wheels on Non Rubicons img_20190519_122417-
Pro Comp Prodigy Wheels with Milestar Patagonia Tires 315/70r17 - no rubbing without a lift while on terribly paved roads. Will be installing 2.5 inch lift to be able to offroad properly though.
mr187
Bryan
2020 JLUR
Law enforcement
Procomp 32 series 17x9 on Patagonia's 315/70/17
Jeep Wrangler JL Pro Comp Wheels on Non Rubicons IMG_6618
Therby
Taylor
Ontario, Canada
2018 JL sport 2dr
Yeah, thanks! . Its a base JL with JLUR springs and shocks. About 1,75” lift. Added 1” bumpstops. Works perfect with sway bar disconnected
Also i think these wheels were 28lbs fyi for the guy above
PadreFreddie
Alfredo Marrero
Vero Beach, FL
Thanks!
ChrispyJL
chris
Rockaway, NJ
Building Mechanic
FYI, the Predators are on 25% sale on 4wheelparts.com
as well as some other pro comp wheels
5 Predators in 17x8.5 5on5 with 0 offset was $474...wish I could pull the trigger, I like those, if they are on sale still next week I am going for it..
and they are 28 lbs? I saw 35lbs somewhere, but maybe that was just the rockwells or my brain farting on itself who knows
Punk'n2doorsport
Willian
Nova scotia
2018 JL wrangler sport, 6spd manual, 3.6L
Trucker
Did you try 16s? I have might be able to snag a set of 16s with 2 inch backspacing think they will fit?
Therby
Taylor
Ontario, Canada
2018 JL sport 2dr
I did not, would be pretty tight. Ive seen a few fit i believe.
16s are good for saving money on tire and a little more sidewall. But to find a good tire that fits on a 16 that isnt E load doesn’t really exist. You can get 35” tire for 17” wheel in D and even some C load which a nicer for a light 2dr
tommyboyii
Tom
Maryland
2018 JLU Sport / 285-70r17 BFG A/T KO2's (c-load) / Pro Comp 17x9 (-6) offset rims / Red Rock 4x4 Stubby Bumper / Bestop Trektop NX fast back soft top
Hope this gives more options.
Pro Comp 7069's. Matte Black. 17x9. 4.75 backspace. Here they are on Stock suspension. Tires 285/70/17 BFG KO's c-load (get c-load in any size tire for my 2 cents). FYI - the backup camera fits these wheels same as stick.
https://www.4wheelparts.com/p/pro-c...lack-alloy-wheels/9300?Style_PQMS=Series+7069
Jeep Wrangler JL Pro Comp Wheels on Non Rubicons IMG_9760
I recently had the 2 inch BDS suspension lift kit installed. I stuck with their nitro shocks. Ride is top-notch thus far (approx. 2 weeks in).
http://bds-suspension.com/product?ma=7&mo=32&ty=110&yr=2018-2019
Jeep Wrangler JL Pro Comp Wheels on Non Rubicons IMG_0374
Jeep Wrangler JL Pro Comp Wheels on Non Rubicons IMG_0375
For what its worth......if you are looking for a non-OEM soft top go with the Bestop Trektop NX ( I went the "low end" Black Diamond; still very substantial weight). Excellent value and it was a breeze to install. It is pure simplicity to use; you only need flip the 2 latches to open up the front cabin; and it takes all of 3-4 minutes to remove the back side panels and the rear angled back window for a bikini top.
These are pre-lift.....
Jeep Wrangler JL Pro Comp Wheels on Non Rubicons IMG_0258
Jeep Wrangler JL Pro Comp Wheels on Non Rubicons IMG_0261
ChrispyJL
chris
Rockaway, NJ
Building Mechanic
@tommiboyii can you put up a pic down the side to show poke pretty please.
also did anyone get hub centric rings? JL hub bore is 71.5 and the pro comps have a 108mm bore, I have gotten hub centric rings in the past, just wondering if they are beneficial or if I can skip them.
can't find anything verifying the hub bore on the pro comp wheels
tommyboyii
Tom
Maryland
Here you go. This was just after install. 4.75 inch back space. offset is -6. Just a shade outside the fenders.
Jeep Wrangler JL Pro Comp Wheels on Non Rubicons IMG_9762
Here is with the stubby bumper. RedRock 4x4 Attack. purchased through extreme terrain website.
it took about an 60-80 minutes for the install (the removal of the factory bumper.......mainly the annoying clips that held in the OEM fog lights.......is the tedious part).
Jeep Wrangler JL Pro Comp Wheels on Non Rubicons IMG_0062 (Edited)
