Post your progress on Extreme Recon package here
GatorWrangler
South FL
'22 JLUR XR
There are 392 owners on this forum who have stated they were unable to pass 99mph.
I think IF the 392 has the higher limit then it may only be for those who were able to get the XR package on the 392. Just my guess as the 392 without XR always had a sub 100mph limit at launch I believe.
Jmos4
2020 Challenger Scat Pack M6/2007 Ram 2500 G56
A wrangler at 97mph would be a scary ride.
Hi,
All depends upon conditions, road weather and surroundings,
I've done 90 most of the way to FL from MI in my wife's JK with no issues, but also making sure I am aware of surroundings and conditions, and been in the buck range a few times...
Really don't understand why mfg's have to put speedimiters on vehicles as my old 96 Taco would die at 85 and after a gear change would cut out at 70, thankfully a place mad a disable device.
If you're not comfortable going x speed then you shouldn't, only wish some people on bad weather days would do that analysts before they leave the driveway
Regards,
kilian73
Virginia
JLUR XR (ordered 11/4)
My build sheet just showed up from an 11/4 order. What's that actually mean? how long after that shows do you typically see your window sticker and ship date?
Cjanak21
Charlotte, NC
2022 Jeep Wrangler Rubicon XR
Cyber Security Consultant
Typically build sheet shows up once it hits the assembly line, and could be about 7-14 days until a window sticker which usually means it is ready to be shipped out +/- a few days. Congrats on the progress! Fellow 11/11 order here just hit D1, so close behind u
Sting Gray Rubi
Erik
Tennessee
2020 Rubicon Unlimited
So I'm looking to buy a lightly used XR suspension setup and swap it out on my JLUR (non XR). I'm going to 35s and would like just a tad more lift. From my understanding, the XR suspension give you ~1.5" over a non-XR Rubicon correct? Thanks in advance!
StinGrayRXR
Brett
Pacific Northwest
2022 JLUR XR Sting Gray - Ordered 2/10/22
Yes, 1.5" over stock Rubi is the predominant understanding. It may certainly vary depending on the various options one may have, but there is some evidence of different springs being used from the factory to compensate. So...it may depend on who you get your take-offs from and what you have hanging off the front of your Jeep. I don't have my XR yet, so just relaying information that I've read from others...
Jmos4
Hi,
So a XR sits 2.5 inches taller than a regular JLUR, as the tires alone only raise it a inch?
Regards,
Jk.
Cjanak21
Charlotte, NC
Hi,
Regards,
Jk.
Nope, total 1.5" over normal JLUR. Tires don't add that much height overall
StinGrayRXR
Brett
Pacific Northwest
Hi,
Regards,
Jk.
You’re probably looking at 2” to 3” taller overall. We’re probably splitting hairs at this point, but technically the difference in tire diameter is 1.6”. So about 3/4” height diff at the axle or “not much” as someone else just indicated.
Edit: just read that someone’s 392 XR was 3” taller than their stock Rubicon. I couldn’t quickly find a non-392 comparison so this may not mean much. I will keep looking.
Jtphoto
Thunder Bay ON
I wouldn’t bother with the XR suspension. All you will get is springs shocks and swaybar links. The other parts are welded or built in like the rear trackbar mount and front extended bumpstops so you will need to buy parts anyway to make it complete. Just buy a quality, complete 2” lift.
in about a month I’ll be selling my XR springs and shocks but I’m up in Canada.
Jtphoto
Thunder Bay ON
They come with BFG KO2 which are on the short end of the stick for 35s. I would agree my XR is only 1.5-2 taller then a regular Rubi. XR is Definitely shorter then our Sahara with a 2.5” lift on 35” Duratracs.
Sting Gray Rubi
Erik
Tennessee
Awesome. I found a used set with less athan 1k miles on it for 300 plus shipping. I'm thinking shipping will be about 100 bucks. Kit includes Front and rear springs, rear bump stops, front coil isolators, front upper control arms, sway bar links, front and rear shocks and front and rear track bars.
Good deal??
Sting Gray Rubi
Erik
Tennessee
Hi,
Regards,
Jk.
Sounds right
Jtphoto
Thunder Bay ON
Good deal??
You will have to see once you get it all together. The rear axle on the XR has a welded on raised trackbar bracket so likely it will be the same rear trackbar you already have. A quick measure will tell you whether or not you will need an adjustable rear trackbar or raised bracket.
Sting Gray Rubi
Erik
Tennessee
His front and rear track bar part numbers are different than mine so I assume they are different ?‍♂
