jack bauer
Ok. So you can get the XR without full time then, which would equate to normal U-joints and no CV, correct?It’s based on the transfer case. Full time gets CVs, selectable gets U-joints
CorrectOk. So you can get the XR without full time then, which would equate to normal U-joints and no CV, correct?
I agree on the center of the wheel. I use top center wheel lip to center of fender split also. I had about 10 spots I measured my 2020 before and after lift so I knew what it was doing in different spots.That would work too. I think the reason for center of wheel to fender is it eliminates the tire variable. As long as it’s stock suspension vs stock suspension, it could be a rubi on factory 33s and an XR on 35s
You know Josh, yours may be different based on your window sticker posted. You have steel bumper group and all others posted so far have plastic bumper. Curious if we will see multiple spring numbers like non XR Rubi’s (hard top, steel bumper, tow pkg, etc).Maybe we should measure from center of wheel to fender? That would take the top variable out of the equation.
If there are different spring rates it might affect my order. I plan on getting an aftermarket bumper and winch so I don't want the steel bumper group. But if the springs are softer they will probably sag too much once I add the extra parts.You know Josh, yours may be different based on your window sticker posted. You have steel bumper group and all others posted so far have plastic bumper. Curious if we will see multiple spring numbers like non XR Rubi’s (hard top, steel bumper, tow pkg, etc).
Good question, I’ve got all of the above.You know Josh, yours may be different based on your window sticker posted. You have steel bumper group and all others posted so far have plastic bumper. Curious if we will see multiple spring numbers like non XR Rubi’s (hard top, steel bumper, tow pkg, etc).
I bet faster than OH to Louisiana, congrats!WOOT WOOT!!!!! Got my build sticker.....now comes the waiting for delivery. OH to PA.....how long you all think it will take?
? I doubt they would put it on a train. It’s probably just hopping a truck if you’re that close.My Jeep was in KZS status on Saturday meaning that it is in transit! Since I live in Michigan I’d imagine I would be seeing it this week right?
Exactly how do I PM @rent with my info ? Thanks !PM your details to @rent, and let him know you'd like to be added. If you have a build sheet it will help him get all the information, and depending on how far along you are see if you can come up with accurate dates for when your build made progress
On mobile:Exactly how do I PM @rent with my info ? Thanks !
