Popping sound when accelerating and slowing down
schuessdog
baily
texas
2020 keep wrangler unlimited Willy’s
Hey guys, I have a 2020 Jeep Wrangler with about 76,000 miles on it and I was curious if anyone’s ran into the issue where when you go to accelerate there’s like a light popping sound that sounds like it’s coming from the front as well as when you slow down any idea of what it might be thanks in advance
59chevyapache
Shane
UT
2019 JLUR; 2009 JKR
Just had this on my 2019 JLUR after wheeling it in Moab. Check all steering components for loose bolts and grease any with grease zerks…sometimes just a matter of a loose bolt or a dry tie-rod end link. If you have non-serviceable components or even ones that are greasable and servicing them doesn’t help, they may be worn out and in need of replacement . I would look at the tie-rod end links first that is what was popping on mine. Greased the end links and good to go.
schuessdog
schuessdog
baily
texas
Awesome thank you so much! I planed on checking all of it today and really see what’s going on
mishkajb
Jerame
Frankfort, KY
2021 Wrangler Sport S JL
I get that on occasion with my 2021 JLU. I think it's the anti-way bar moving. It's not as tight as the other components and will move or flex. Everything else seems in good condition.
Roland79
NWA
2018 Jeep JL Sport (2Dr, Soft Top)
My ‘18 JL is doing the same thing after a full suspension lift. Did anyone determine the source of the sound?
