planetech
I spoke with Will. He sent me the spring isolator kit for the 3.6 non e torque wrangler and the front spring correction kit for the bow. This did correct the problem with the lean and the bow. As far as the noise, there is no way the springs can lose enough tension to cause the noise. Trust me, it doesn’t flex enough and your brake lines are not long enough to unload those springs. I would climb under there and check all the hardware for torque. Pay particular attention to you rear sway bar links at the sway bar. Mine loosened up on the passenger side and caused noise. I put the nut back on with blue loctite.planetech, what did you and/or MC do to fix yours? My Jeep had a 3/4” passenger side lean and my front coils were bowed significantly (worse on passenger side). The guy who installed my lift ended up adding the MC isolator pads to correct the coil bowing issue. He also added the MC spacers/shims to help level the Jeep. Now, every time I go over a bump, something rattles/knocks from underneath. Sounds like it’s coming from the rear driver side. Sounds like something is loose. I talked to my installer about it and he said it’s probably from placing the metal spacers — apparently he stacked 3 of them and he said that’s probably causing the rattling. I won’t be able to have him check it out for another week. I know everyone swears by this lift kit but in all honestly, this has been a headache for me ever since the lift was installed ?
