Parking sensor flakes out
JJ_WA
JJ
Puget Sound, WA state
2002 Dakota, 2017 Cherokee, 2023 Willys XR
Retired US Army, Higher Education
Back in June I started getting the "Parking Sensor not available. Wipe sensors" message. Since the Jeep is parked in the garage, I suppose it's possible dust covered the sensors. I wiped them off and it's fine for a short time. It will flash, turn off while driving (turning back on the sensors). After parking at my destination and getting back in to depart everything is fine for the entire trip back home. There may be an intermittent short somewhere, but I have no idea where to look. The sensors themselves seem fine.
Has anyone else had this issue? Were you able to resolve it?
Thanks!
Jeep Wrangler JL Parking sensor flakes out 20240606_120416
Johnny B
PA
2021 JLU Sahara
Can I ask, have you changed tire/wheel size? Replaced a flat using the rear mounted spare?
JJ_WA
JJ_WA
JJ
Nope. Only rotated once at the dealer - back in March/April. No changes otherwise.
Wagabond
Martin
Montco, PA
2024 JLURX
Sounds like you are having a similar issue to me. I get the error intermittently. 2024 JLUR with XR package, new in June of this year.
I have seen others ask about tire sensors or changing tires, and wonder what the thought behind that being linked is. Some interference with TPMS?
@JJ_WA - From your profile it looks like you also have the XR package. Wondering if that has anything to do with it?
Johnny B
PA
2021 JLU Sahara
Not a sensor reflection issue then. Are you running the dual battery setup (one for the ESS)? Just trying to eliminate the easiest issues that some have had.
Johnny B
PA
2021 JLU Sahara
Wheel weights and TPMS sensors have caused issues for some. Not all. So clocking the wheel at times helps. I guess that is more or less a reflection issue with the park assist sensors.
JJ_WA
JJ_WA
JJ
I have the eTorque engine. Hopefully it's not a battery issue (already).
JJ_WA
JJ_WA
JJ
I don't know if it's XR related, but certainly could be Safety package-related. I think we would need more folks indicate they are also experiencing the issue.
Wagabond
Martin
Montco, PA
2024 JLURX
Thanks @Johnny B. I was wondering if tire size or steel bumpers may be contributing
just looked out the door to check. Valve on the spare tire and hence TPMS is at approx 7 o’clock position
Johnny B
PA
2021 JLU Sahara
It happens, and it is unavoidable. However, eliminating the secondary battery (the right way), and disabling the ESS is a step in the right direction. Let's be honest, one battery for everything makes life a little easier.
Johnny B
PA
2021 JLU Sahara
One quick way to know. Look at the mounted spare, look for the wheel weights and/or TMPS (valve stem) and rotate the spare on the spare carrier. Try to clock them up and away from the bumper sensors. That's just a little time and no money to try that route.
Wagabond
Martin
Montco, PA
2024 JLURX
@Johnny B Hit send too soon earlier and edited to add that the valve is at about 7 o’clock position. will look at the wheel weights and try your test when I get a chance.
JJ_WA
JJ_WA
JJ
I have only a single 12V battery with the 3.6 liter eTorque. There is the 48v battery under the vehicle, but it's not the double battery system for the regular ESS.
Megawatt
Sin City aka Vegas
money pits: Turbo Busa, Street Bob, 22JLUR snazz, 5.0 mustang MT
Powerplant operator
I rotate spare tire one lug hole CW then drive. Find the best rotation till issue clears.
alphawolff
california
2021 JLU
There's an update for this. Had to do it on my 24 392. The sensors still flake out sometimes but it's better than before. I suspect we'll get another update in the future to fully fix the issue
Jeep Wrangler JL Parking sensor flakes out 1723837112573-at
