P0174 / P2098
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
Hi all. Filled up my fuel tank last week and got P0174 fuel system 2 and P2098 downstream post-catalyst fuel trim system 2 lean downstream fuel trim system 2.
Had a rough idle one day on startup and when I was stopped for a short time. Though maybe I got bad fuel so I cleared the codes to see if they would come back. Codes came back one more time but never had the rough idle again and once it got to a little under 3/4 tank no issues. At this point I was thinking definitely bad gas. Let my tank get down to just under 1/4 and filled it up last night. Get on the highway this morning and as I get off my exit for work auto start stop disabled which I know is a precursor to the check engine light. Check engine never came on and I did a quick scan and no codes were present. Leaning toward intermittent driver side O2 sensors? What say the good people on this forum?
2019 JLUS 3.6
Stuckinthesand
Stuckinthesand
CJ
NJ
I had same 0174 code and rough idle, it was a bad downstream O2 sensor. Check for oil leak from the valve cover, that’s what caused my O2 failure.
Did you pull the fender to replace? I am assuming it is easier this way. This is driver side correct?
jadmt
jeff
montana
the area the valve cover usually leaks is the back corner of the passenger side.
Stuckinthesand
Stuckinthesand
CJ
NJ
Update: sensors are crispy. Definitely pull the fender to get to them. 100x easier. Recommend a breaker bar unless you want to scratch yourself up on the 2nd sensor.
Jeep Wrangler JL P0174 / P2098 IMG_3060
Jeep Wrangler JL P0174 / P2098 IMG_3059
Stuckinthesand
Stuckinthesand
CJ
NJ
lmao those things are toasted
Yeah and that was only a week after I got the original code that I figured I got bad fuel. Weird to me that once it got below 3/4 or around there it ran fine and I never saw a code again until I filled back up. Thanks for the heads up I saw in one of your previous posts on O2 sensors about resetting fuel trim adaptations.
