chstew05
I have a 2018 JLU Sahara with a 3.6L. While driving, the auto start/stop unavailable and check engine lights came on with a suddenly rough idle.
I popped several codes P0174, P0300, and P2098. I replaced the upstream bank 2 O2 sensor. P2098 cleared and the idle isn’t as rough. I erased the codes once but they’re still showing even though the check engine light isn’t on any more. I still have the P0174 and P0300 codes (says permanent code). The exhaust has a stronger smell than normal.
While running, the Bank 1 short fuel trim bounced between -4.8 and 0. Lone fuel trim was pretty steady at 4.3. Bank 2 was steady 32.8 for both short and long.
I’m trying to avoid chasing my tail or leaving it at a shop for weeks on end. Is there a quick way to isolate it a vacuum leak, coil/plug/wire or injector issue? I’m pretty mechanically inclined but the V6 is much different than my previous 05 TJ.
Appreciate any advice.
