Over size spare help
brandon3_16
brandon
Pottstown Pa
Charger SRT
Hey guys, picking up my 4xe Sahara tomorrow!! I've already ordered new rims and tires and have a question.
Rims are a 20 inch, same as stock but went with a 33x12.5 tire. Will the spare still be able to mount in the stock place without any mod? If I need a new mounting kit what do you guys recommend??
Sholmberg0311
2021 JLUR 2.0T
Adult baby sitter
You should be fine. But for piece of mind ive seen quite a few people run the Rough country spare tire relocation bracket
jludave
The Isle of Long
IT Manager
I have a Sport Altitude with 18 inch wheels (same as Sahara but black). I upgraded to 33 inch tires. After doing so, my tire rubbed the bumper on the lower right. I installed a RedRock 4x4 Spare Tire Relocation Bracket and that fixed the rubbing. You will need extended bump stops if you install a relocation bracket.
You won't know if you need a relocation bracket until you actually try fitting the spare with the new tire on it.
brandon3_16
brandon
Pottstown Pa
Charger SRT
Ok, looks like it might be a wait and see approach. Thank you both for your input.
Mikester86
Michigan wishing I was on a trail...
2022 JLR
What people never mention, or tend to forget is you need to take the spare relocation bracket's weight into account. The tailgate can handle a maximum of 85 lbs.
I think the Rough Country bracket weighs in the range of 13-15 lbs. That is substantial in my opinion.
