Over heating without a code JL 2020
Sabrina Peel
Sabrina
Globe ax
2020JL wrangler Rubicon
Hello, I have a 2020 JL Rubicon 2.0 with turbo. My jeep is over heating 242 to 246 degrees without throwing a code anywhere for dealer to fix it. Does anyone else have this problem?
JandS
Midwest
4xe | Exige S | R wagon | V Wagon | MB S65
Where are you getting this number and under what conditions?
Sabrina Peel
Sabrina
Globe ax
I don't know why I'm getting it other then jeep engineering says its ok and to run it.. Me knowing it's bad and not stupid I don't want to blow up coming home from work. I'm wondering if its more then just me..
Oldbear
Dwayne
Bowling Green, Ky
16 Ram 1500 Ecodiesel; 20 JL Sport S 2 door
Is the heat gauge into the red zone? I’ve no idea what degree F is usual, but that sounds pretty normal to me. Is this a higher than usual reading for you? Does it only happen under extreme conditions?
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
That is close to boiling over.
Oldbear
Dwayne
Bowling Green, Ky
Does anyone “know” what the “normal” range is? With the pressure cap I know it’s above normal boiling temps but know exactly where. Anybody?
Bob Burd
Bob
San Jose, CA
www.snwburd.com
Mine usually runs below 220F. Climbing hills it can go to a little over 230F but the electric fan usually kicks in and keeps it from going higher. You can use the offroad pages to watch radiator and oil temps to see the fan in action. Even on a very steep dirt/rock hill climb I've never seen it reach 240F.
sandygar4
Gary
Oregon
2019 Wrangler Rubicon
I had an overheating problem coming back from hunting (2019 JLUR 2.0). The temp gauge turned red. Pulled over and turned off the engine and waited for the engine cooled off. When I started out again I was only able to go about 40 yard before the temp gauge went red again. Thank goodness for AAA I had to be hauled 87 miles to home. Towed to dealer and they found a leak and had to replace a pipe and gasket. Still smells of coolant but temperature seems ok. I would like to know what the normal operating temp is. On the gauge it goes back and forth from 190-235
