Oracle Oculus LED Headlamp DIY Install Video
Northridge4x4
Summit Sponsor (Level 3)
Silverdale, WA
www.northridge4x4.com
2016 Sahara JKU, 2013 Rubicon JKU
Seller of badassery
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
Great video showing just how simple it is to swap out your headlights to the ORACLE Oculus for a nice upgrade! Thanks guys :rock:
davidafuller
Hartford County, Connecticut
2019 Wrangler JLUS (Granite Crystal)
CPA
Anyone, including @ORACLElights, have a DIY install video for the LED fogs?
ORACLElights
Metairie, LA
davidafuller
CPA
Hey David, we just put up an install video and install guide on the product page: https://www.oraclelights.com/products/oracle-jeep-wrangler-jk-high-performance-20w-led-fog-lights. Give us a call 1-800-407-5776 if you have further questions.
Thanks--my problem is less so that I don't know how to remove the factory fog and install the LED. That part would be pretty straightforward. My issue is really more so that I can't even access the brackets to remove and replace the fogs. My bumper looks slightly different than the one in your video; it's the Sahara factory plastic bumper. There is a protective piece that makes it so you can't even access the fog bracket to remove/replace. I took off all the push pins I could access and it's still stuck in place.
I think someone mentioned elsewhere that I'll need to remove the eight push pins holding the factory plastic skid before I can remove the backing to access the fogs. Curious if anyone else can confirm before I go thru the hassle.
Thanks all!
