Oil in intercooler piping
Tpsillos
Trey
South Carolina
2021 JLUD
Welding Inspector
I was messing around with some new intercooler pipes from AFE and noticed some oil in the factory inlet intercooler pipe. I doubt my turbo seal is going bad already so I'm leaning towards to PCV system being the culprit. Anyone know if adding an oil catch can or if rerouting the lines could keep oil out of places I don't want it?
ErAcEr
Matthew (Mateo)
Indianapolis, IN
2018 JLU, 2021 ZH2 , 2018 Z900, 2013 Vulcan 1700
Engineer/Technician
A catch can should solve that issue. I had to install one on my supercharged bike as oil blow by from crankcase pressure would feed back into the air induct system. Talking with the mechanics at work: that is the nature of boosted applications.
TaiMc
Tai
Houston, TX
www.instagram.com
'18 JLU Sport Mojito!, 3.6L & '18 Ninja 400 KRT
Communications Manager
2021 ZH2: YOU MUST PROVIDE PICS in this thread: ???
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
There will always be oil in the piping. Think about this 100k rpm of the turbine wheel spinning and the compressor wheel sucking in it will no matter what vacuum oil inside ! New engine or old engine. As mentioned above. A PCV oil separator will solve this problem I have it on my Supra as far as the Jeep diesels. If you are really analytical I would remove the intercooler and piling once a year or so and degrease /wash and re install. This is an exaggeration. But I do it on my 2jzgte because I care a lot and all the $$$$ that went into building it ! My 2 cents lol
Tpsillos
Tpsillos
Trey
South Carolina
2021 JLUD
Welding Inspector
I have a catch can on my Dodge cummins, the intercooler piping on that truck is pretty clean. They make catch cans for the older ecodiesels but as far as I know no one can keep the computer happy and CELs come up installing that setup on these engines. That is why I figured I would ask the gurus here for opinions. The intercooler cleaning option might be the only way to go, maybe every 100k miles?(I have 58k on it at the moment)
PhoenixM3
2022 GR86, 2023 Wrangler JLURD
I have an OCC form a past car. Where do I install it on the Ecodiesel?
OBD
Thomas
Arkansas
2021 Jl Wrangler ,2016Soul,Dyna,Sportster,HD
I'm ordering the Mishimoto catch can for my 3.6 next month. They are not cheap but appear to be well-designed and a quality item.
PhoenixM3
Then, I’ll checkout their website and determine where to install the one I have. Thanks!
  • Like
Reactions: OBD
OBD
Thomas
Arkansas
Might check out YouTube.....Lots of install videos there..
azjl#3
North AZ
This^^^ Turbos do this.
