Off-road Wheel Chocks?
40”JLURD
40”JLURD
Ross
Southern California
2021 JL Unlimited Rubicon Diesel
Bad Mother Fucker
I'm looking for superior durability, stability, and traction. So I bought MaxxHaul heavyweight wheel chock. Couldn't be more wonderful
Same ones I went with, I agree they seem pretty awesome . Haven’t had the chance to use them yet but they seem like they will grip well on a variety of surfaces.
Dalton07
Dalton
4730 Gladwell Street Texarkana, TX 75501
2010 Daewoo Tocsa
I purchased these Camco 44414 Wheel Chocks to use on vehicles while working on them. They were great! The whole thing is made of high-grade plastic and is very lightweight. It is sufficient enough to hold down my RV with 29-inch tires. I bought four of them and they can all stack together. Overall, I'm very pleased they're lightweight they're cheap but they're doing a job I have not had any problems with them and I have used them a few times.
daviddarwin091
Ford Ranger
An X-chock wheel stabilizer usually does the trick when it comes to steadying and stabilizing my rig in tight parking spaces. This Bal deluxe tire chock is no exception, providing greater rig stability and security than many of its competitors.
four low
central New York
2018 JL
A heavy wheel chock, preferably grippy rubber so it won't slide, big enough to stay put. If you need a wheel chock, conditions aren't ideal. Big and Heavy , the Maxxhaul type are what I have. I have a light rope attached, so I can yank and retrieve from the drivers seat,when you take the pressure off; you want the rubber because it won't mark you or the bodywork when you reel it in.
blnewt
New Mexico
Just ask @cosine he knows!
With 40" tires, Maybe you should back it against somebody's Smart Car. That should fit just right.
Only if the smart car is parked sideways, and not if the wind is blowing :)
BoneSoldier
Daniel
Miami, FL
Wrangler Unlimited Sahara 2019
When I was out on some off-road trips, I had the same issue with finding chocks that could handle larger tires and tough terrain. I ended up getting a set of chocks that were both sturdy and collapsible, perfect for when I'm on dirt or uneven ground. They’re light but strong enough to handle my larger tires, and the collapsible feature makes them easy to store.
One thing I really liked about them was how they gripped the tires, even when I was parked on a slight incline. I’ve used them in a few off-road situations now, and they’ve worked great. Definitely worth the investment if you need something durable but also convenient to carry around.
