OBD splitter?
rickinAZ
Rick
Phoenix
2026 MOAB 392
Does anyone have an experience with these? My intention is to use both a Scangauge and a Tazer Lite in the same OBD port. Any issues or words of wisdom?
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@rickinAZ
The Tazer Lite does not plug into the OBDll port.
You install the Tazer JL Lite, by disconnecting the 2 cables that plug into the gateway module and then those 2 disconnected cables get plugged into the Tazer JL Lite.. then you marry the Tazer JL Lite to the JL.
As for your ScanGauge ll, now it's cable has one end that does plug directly into the OBDll port, and another end that plugs into the ScanGauge ll, itself.
I'm not sure if the Tazer JL Lite and the ScanGaugell will play well together.... you let us know. 8-)
Just watch that the ScanGauge ll does not wake up UConnect constantly / all night and kill your JL's battery.
rickinAZ
rickinAZ
Rick
Phoenix
2026 MOAB 392
@rickinAZ
Well that simplified things. Obviously my due diligence failed me. Thanks again!
redracer
Robert
Manteca, CA
2023 4xe Rubicon
FYI, I have the original Tazer JL that does use the OBD port. I ended up buying a Y cable so that I could use my bluetooth module as well. It works great.
