Normal t-case play?
Lloyd from TX
Houston, TX
JLUR'25 2.0T
Hey everyone!
Check out this video – does this amount of driveline slop look normal for the transfer case? This is me spinning the rear wheels while the tranny is in Park. I can sometimes feel this clunk at low speeds, like creeping through a parking lot. Jeep only has 4k miles on it.
Appreciate any input – thanks!
nU7OuxIx
Chicago
2025 JLU Rubicon X, YJ, Impreza
I'll have to check mine later but it looks similar. Mine also sounds similar too. I've been meaning to ask here about the clunking.
It seems like mostly going from gears 2 to 3 there's a bit of a clunk more often than other gears, but usually I'm going uphill too. I figured with as many sensors and connections there are, if it was a real issue, it would pop up with an error.
Lloyd from TX
Houston, TX
JLUR'25 2.0T
Thanks man! Mine does it even without shifting – just a random bump or lurch at low speeds. You get that too?
Also, this is new – it wasn't doing it before. I did take it on some light off-road trails and now I'm overthinking every noise. Could anything actually wear out that fast, or is it just in my head?
Reflektr
Travis
Illinois
2025 JLU Willys
Equipment mechanic
I also noticed this on my ‘25 Willys 6-speed manual. I heard a sporadic clunking while shifting and it would’ve liked to have sent me howling straight for the nuthouse. I crawled under it one day and rocked the output on the t-case and it made the same exact noise I was hearing.
I guess drivetrain slop is pretty common but more noticeable in my case because it was a manual. It never really put my mind at ease, but at least I knew what it was lol.
Lloyd from TX
Houston, TX
JLUR'25 2.0T
I don't hear it - I feel it. Jeep lurches at low speeds, and honestly it feels like play in the transfer case gears. That's my gut feeling anyway.
And based on the video - is that amount of play in the transfer case normal or too much?
If anyone knows, let me know. Thanks!
cj7ox
Sean
Yorktown, VA
1985 CJ-7, 2020 JLURD, 2006 Ram 3500 CTD
A certain amount of play is normal. I can't really tell if what you have is within spec. Even the amount your video shows wouldn't create a lurching affect. Does the "clunk" occur just when you start moving? Or does it occur and continue after the vehicle is in motion?
Lloyd from TX
Houston, TX
JLUR'25 2.0T
Thanks for the reply! It doesn't do it when I start moving- it happens while I'm already rolling, but only at crawling speeds. It's not constant - just a random bump here and there. I notice it most either during the 1-2 upshift on the auto trans, or sometimes in 1st gear when I lift off the gas.
What else could it be besides play in the transfer case? Any ideas what else I should be looking at?
cj7ox
Sean
Yorktown, VA
Does the thunk occur more often when turning, or going straight? You may have a bad front axle u-joint. I lost a u-joint cap on the drivers side a while back (no idea how), and I would hear a thunk every so often at slow speeds, especially when turning left. Jack up your front end and slowly rotate the wheel to inspect the u-joint on each side. That could be your issue. 🤷‍♂️
