Noise From Dash
Upnarms
AZ
2019 JLUR, 2003 TJ X
Have you put your hood up then put the ignition into ACC or ON without the engine running? There is a high pitched sound coming from the electronics in the engine bay.
Yes! I have that too. I believe it's related to the annoying hydraulic electric steering box, which also makes annoying whining noise when steering. Junk in my opinion
LucidDreamer
Tampa, FL
2020 Wrangler Sport S V6
I heard the same kind of noise on mine a couple of times too. Looks like it happens when it is pretty hot outside and the noise was coming from the left driver side around the speaker area. The noise is like whistling or an electronic type.
Did anyone figure out what may be causing this noise?
Upnarms
AZ
Windshield seal. Dealer fixed it, said windshield was 1/4 inch out of where it should've been seated. You can verify by putting masking tape around frame of glass and see if it goes away
