Paulguy100
Most times when I shut the engine off there is this buzzing sound. Is this normal?
Yes.Most times when I shut the engine off there is this buzzing sound. Is this normal?
Yes, lasts exactly 3 minutes. Coolant pump running to cool the turbo.Most times when I shut the engine off there is this buzzing sound. Is this normal?
But that sound should come from the proximity of the exhaust or by the DEF tank according to the manual. This one comes from near the engine - from the hood.Yes its normal. It's for the DEF fluid system. It pumps the DEF out of the lines and back into the tank because DEF can freeze below 12 degrees or crystalize in the lines and cause issues.
I know there are some electric pumps that run and I here that right before shutdown, like when I put it in park .... a lot of things on the JL are driven by electric motors and switches and it took me awhile to get used to hearing different soundsBut that sound should come from the proximity of the exhaust or by the DEF tank according to the manual. This one comes from near the engine - from the hood.
