omnitonic
- Michael
- Apr 20, 2021
- Southwest Virginia
- 2021 JLU Willys in Sarge Green
- Occupation
- truck driver
The official JL procedure for the parking brake seems to be to tighten the cables via the access inside the console. I'm at the upper limit of travel on that adjustment, and my parking brake just barely holds.
In my research, I've discovered that these parking brakes use the same hardware as the JK. There are tons of "how to adjust your star wheels" tutorials aimed at the JK, but nobody ever talks about star wheels and the JL, except when trying to loosen the parking brake shoes in order to get the rotor off.
I'm wondering if I should just try pulling my calipers, pulling the boot, and attempting to adjust my star wheels tighter. I also suspect there's a good chance they're seized anyway, and all the hardware inside the drum is probably a rusty mess. Maybe, maybe not. I've seen a lot of Jeeps that were in far, far worse shape, as far as the parts I have actually accessed. Nothing is especially corroded yet, and I haven't driven through much salt or thick mud. I have driven through a large number of deep mud puddles though, and I have done a lot of stream crossings. There has to be a reason my parking brakes are just shot to hell. Maybe I get lucky and all the hardware is still pristine, and it's just the friction material has come unglued.
Who knows.
Also, I can appreciate that pulling the axle would make this job dramatically less of a hassle. I've never actually pulled an axle on anything that wasn't a full float, and I have no concept of how involved that would be. I guess there are clips inside the pumpkin? I need to change the diff fluid anyway. It's about time. Is it worth pulling the axles, or would I be better off leaving well enough alone?
Who knows.
