No key memory or am I doing something wrong..?
Spearmin
Eric
NY
JLU
Scenario 1:
A.I hit the remote start on the key.
B. I go outside hop into the JLU.
C. While Driving I turn on the heated seated and stearing wheel.
D. I arrive at My destination.
E. I turn off the JLU lock the doors and walk away.
Scenario 2:
A. 15 minutes later, I hit the auto start on the key.
B. I return to the JLU (its already running).
C. I climb inside the JLU and the heated stearing wheel and seats are turned off and ice cold.
Shouldn't there be some sort of memory that holds my last settings for at least a few minutes? Am I just missing a setting somewhere?
Spearmin
Eric
NY
JLU
OK that will work where is that setting?
Snayte
Nathan
Eau Claire, WI
2019 JL Sahara Hella Yella, 2017 Ram 1500 Longhorn
It is in the settings accessed through the radio. It might vary exactly where based on the radio you have.
Spearmin
Eric
NY
JLU
I may have found it. I don't see any reference to temperature though. Seems to be saying if I use remote start then turn on seats and stearing wheel.
Jeep Wrangler JL No key memory or am I doing something wrong..? IMG_20191016_161301
Snayte
Nathan
Eau Claire, WI
Correct, you can do remote starts or all starts. The temp is in the manual. I wish it were adjustable.
Spearmin
Eric
NY
JLU
So there is somplace to engage the temperature setting but it's in the manual as to how to...
Rubicollie
Orlando, FL
2019 Ocean Blue JLUR
Veterinarian
All you do is turn the auto-on feature on. It's not something to adjust. If you select auto-on, it comes pre-programmed (non-adjustable) to turn the heated steering wheel and heated seat if the outside temperature at startup is below 40 degrees.
Gellie
Larry
NJ
2020 JLUR
When I picked up my 20 JLUR, my dealer went over every setting. After a hour I said ok got it. How do I save them? He said save them? , you bought a Jeep not a Lexus. LOL
Spearmin
Eric
NY
JLU
Yeah I think I was just spoiled from my BMWs.
