AFD
- Oct 13, 2021
- Northeastern US
- 2023 JL Rubicon (2DR/V6)
Are you sure you're not referring to the 'find-a-Jeep' tool with the shitty options listed on the left-hand side instead of the full 'build-a-Jeep' configuration tool?The configurator on jeep.com is not programmed to be accurate for what can be ordered today. It is programmed as a tool to find what is currently or on order to be in dealer stock somewhere in the country.
So theorettically if you can build it on the configurator, then that Jeep exists somewhere. The stupid part is it will only show you stock up to 250 miles from what ever zip code you enter. So though it may exist, you may have difficulty actually finding it. Would be nice if it would tell you exactly where that one particular build is, even if it is eight states away.
Afaik, the build configurator has always been accurate, albeit a bit behind compared to the most recent dealer order guides, as far as options and pricing is concerned. Iirc, some of the sponsor dealers here actually require you to submit a copy from the build configurator before placing a factory order.
I do agree that the Jeep finder tool should show you everything available across the US and yes, it's terribly inaccurate.
