No audio after loud crack, ’24 Rubi, basic audio
wjcubellis
William
2024 Rubicon
I installed a powered sub and it was doing some intermittent weird stuff. I had not grounded the unit chassis to frame ground and read that I should. Before I could... I heard a loud crack and then no audio. Like “true_cascadian” in (https://www.jlwranglerforums.com/forum/threads/no-audio-after-aftermarket-amp-install-error.151143/), The head unit still powers on and responds like normal. Shows music playing but I have no audio. Done hard resets. Verified both fuses for radio and amp, changed sources, all to no effect.
CloakedWillys posted (The issue you are most likely having is the can bus system is seeing the speakers not connected. You need to run an adaptor on the JL's. Pac audio makes it easy. https://pac-audio.com/products/ap4-ch41-r-2) but it doesn't list commutability for 2024 and I don't know how or what this will do to fix the problem.
Any ideas appreciated?
