No Audio Front Speakers
BrentMG
Brent
Central Texas
23 JLUR XR
So probably around the start of the year I removed my Taser for a dealership visit. Tried putting the plugs back into the BCM but ran out of time and drove there with it unplugged. My screen and USB ports wouldn't come on and had no volume at all. Get done with the visit plug the Taser back in and everything works, minus my front speakers.
I've tried umarrying and marrying the Taser, disconnecting the batteries fude and fender ground and even put the stock speakers back in and nothing has worked. About a month ago I installed some knee panel speakers, hoping with me messing around down there maybe something would click. Same result.
I have an insane audio JL3001 installed, messaged them and tried everything they have suggested, which is pretty much everything above. Has this happened to anyone else, and if so how did you fix it?
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
When you re-married the Tazer did you go through all of the steps? I lost my front speakers for a while until I did them all. They're pretty convoluted.
BrentMG
BrentMG
Brent
Central Texas
23 JLUR XR
I did the entire marrying process. I also checked the fade settings as well as going through FM, AM USB etc. Forgot to mention that.
rhm
Randall
Haslet TX
2021 JLU Willys
following, I am having a similar issue on a 21 JL except I lost front speakers at the installation of the tazer and have since unmarried and been told to unhook batteries to reset. maybe tonight ill do that. im also having an issue where the tazer will not allow me to cycle the ignition.
BrentMG
BrentMG
Brent
Central Texas
23 JLUR XR
Only other "issue" I had with the taser was when I had the seven inch screen. After a handful of months the turn camera wouldn't work and I had to go through the process again.
