Nitto Trail Grapplers chunking out?
gr8jbull
Jason
Lubbock, TX
2020 JL Rubicon Recon 2-dr 2.0L Auto
Running 37's @ 37psi with 3.5" lift and... drive rear wheel {only} is chunking out; crazy wear on outside lugs. Suggestions?
Jeep Wrangler JL Nitto Trail Grapplers chunking out? B7F21750-C5A3-4C59-B286-B10F5ADB8ED4
Kreepin1
Kirk
Central Illinois
1982 CJ7, 2006 TJ, 2012 JKR, 2021 JLR
There appears to be a lot of cracks in the carcass as well. Are these new tires? If so, go back to the tire shop and have them replaced. If not, check the date of manufacture, those tires are shot…
TKL223/3
Jon
Arkansas
Jeep JLU Rubicon
With the amount of weathering that’s not on the tread blocks, It looks like you’ve had those tires on your Jeep for years?
Tool Guy
So Cal
2019 JLUR, 2020 BMW Z4, 2021 Tacoma, 2022 X3 M40i
37 PSI is a bit on the high side for 37's, I'd be more like 28 PSI on a Load Range D. They do look like they must be few years old. Any idea of age? BTW Air pressure is not a factor in the chunking.
XJfanatic
El Paso, Tx
2020 JLU, 2020 JT, 2000 TJ
The dry rot in the carcass between tread lugs is a Nitto thing. Every set I have seen over a year old looks that way. My RG have 15k and 16 months on them and look the same.
chunking looks like they rubbed something at some point. Could have just taken time and miles to open up. Were these ever off-road? Spun from lack of traction?
