Newbie tire integrity question.
Squirrely Dan
Denver, CO
2023 Wrangler Sahara 4xe
Do you guys worry about small tears in the superficial rubber of the sidewall? Hard to tell from the pic but this flap is about the width a penny. So like 1.5mm deep at most. FYI these are E rated AT3s.
Jeep Wrangler JL Newbie tire integrity question. PXL_20230803_192904117
Willysfan
Jason
2023 Jeep Wrangler Willys
Machinist
As long as I have a spare, I’m cool. I would probably replace it before a big trip though. Error on the side of caution.
azwjowner
Phoenix
No because on an E tire there are either two or three physical sidewall plies. As long as the inner one is undamaged, it's fine. However, it will make you more susceptible to damage in that same location.
Furthermore, if you do any regular offroading, you will experience this fairly often. You can't reasonably replace a tire every month whenever you get a new gash.
The long-term solution would be to (1) adjust your driving style, if possible, to be more careful with sidewall rubbing on rocks; (2) be sure your air pressures are low enough (reduces sidewall damage because the tire can deflect out of the way); and (3) switch to a thick carcass mud terrain like the Cooper STT Pro or Nitto Trail Grappler if you are still experiencing gashes and want to avoid it.
For example, @wibornz has run thousands of miles on his Mickey Thompson Baja Boss tires with sidewall gashes: https://www.jlwranglerforums.com/fo...mpson-baja-boss-at-20-000-mile-review.112425/
Squirrely Dan
Denver, CO
Super helpful. Much appreciated.
