New Wrangler Owner installing Subwoofer
Bnelsonjax
Omaha
2019 Jeep Wrangler
Hi,
This is my first wrangler, so i was hoping to get some advice from some experts. I have a Kicker HS10 that i want to install in the rear compartment. I've run the RCA cables to the headunit, but im not sure what i want to do with the power wire and ACC wire. Can I tap into the Cigarette Lighter plug that's in the rear?
Thanks for any advice you can give.
2024-JLUR-X
Orlando, FL
2024 JLUR-X with Extreme 35 package
Depending on the size of the sub you should really run the cable to the battery.
Bnelsonjax
Omaha
2019 Jeep Wrangler
its 180watts but i think you are right, i wouldnt want it to melt the wire or cause some electrical issue with the onboard computer. I'll go ahead and research how to remove the door sills and run cable to engine compartment
Ty!
