Negative Bus Bar
bobholthaus
bobholthaus
Bob
St. Louis, MO
2023 JKURD AEV JL370; 2014 GC Overland Diesel
Technology Integrator
emarrero
Ely
Downstate NY
2021 JLUR, 2020 Cherokee Trailhawk
i write code
It probably has to do with Duty Cycle.. I won't recommend which direction to go, but I will say I follow the 12v charts, accounting for engine or environment temperature and up to 2% loss whenever I do wiring.
I've got enough on my mind usually to not have the spare capacity to also worry about my wire sizes. I like to be conservative when dealing with large currents.
Sharing this 12V wire size guide
Jeep Wrangler JL Negative Bus Bar IMG_20240303_172015_216
Pareto Offroad
Brandon
Durango, CO
2020 JLUR
Makin’ sawdust
Wow, I didn't know this existed. This may work perfectly for me!
I agree! I just searched Amazon for “terminal extender” and found that. Looks to be great for a winch, arb twin, and an accessory box. I’ve got these myself and can’t wait to try it out. Mine will be here in 2 days.
The listing says it’s “bronze”. That’s not the best conductor, but I’m willing to try it out and will return if I see more than a 0.3-0.5% loss from one end to the other.
BDinTX
Dallas, Tx
Mguy
Far Away
2020 JLUR 6spd MT
bobholthaus
bobholthaus
Bob
St. Louis, MO
Please let me know what you find out. I'm going to try this solution before I order a custom cable to run up to the Blue Sea setup that I already installed and was hoping to use. I also need to call Warn, which I will do.
bobholthaus
bobholthaus
Bob
St. Louis, MO
So I wired up the Amazon piece today and I think it will work perfectly. The three lugs are perfect: 1 Is my winch ground: 2 is my hood solar ground and my switch pros ground; and 3 will be for my Kraken/ARB twin ground. There aren’t much threads on the main nut holding it on, so I used blue locktite. I used the thinner one and flipped it over for my diesel. I think it looks pretty OEM. I’m completely happy.
The third pic of my positive: I couldn’t seem to get that nut that I’m pointing at totally tight; that’s where I connected my positive feed from my solar panel. I’m wondering if there’s a bolt in there that’s spinning. I got it snug with blue loctite and let it be. If you think I need to worry about it, please advise.
Jeep Wrangler JL Negative Bus Bar IMG_3738
Jeep Wrangler JL Negative Bus Bar IMG_3739
Jeep Wrangler JL Negative Bus Bar IMG_3740
