Need to replace Rubicon Fender Trim
AZJeepGuy
Ron
Arizona
2022 JLUR Hydro Blue
The rock won.
Need:
Right Front Fender Trim - Could not find on All Parts. Best option
Trim rivets - Has anyone found these on Amazon
Fender to body clips - The fender is separating from the body. They are design for that but then I need to pull it off and replace the clips? These work?
Anyone in the Phoenix Area have a take off set of stock black Rubicon fenders?
Some Random Guy
Washington
Comptroller
MP Concepts seems to be the best replacement as far as availability. It does NOT come with hardware or instructions. NR4x4 never has the nut clips in stock when I look, but does occasionally get the white W clips.
I was able to save almost all my front clips by going behind the inner fender flare with some needle nose pliers. If you have the new fender in hand it’s easy to figure out where they all are.
Edit: more info On my install thread
AZJeepGuy
AZJeepGuy
Ron
Arizona
Thank for the link. I have long needle nose so I should be able to save some.
