Need some assistance after Installing LED headlights.
Jeeplover278
Peg
New York, Oswego County
2021 Wrangler
I think the lights I got were wired wrong as the harness for the Halo Ring is short, I tried swapping the headlights around and realised that they were wired backwards, leaving me with little room to reach the fusebox. ( The L and R, were either assembled wrong or they were wired with the harness attached to the wrong headlight because when I swapped them I had plenty of room, BUT the headlights then did not line up with any of the holes. So I swapped them back where the L is actually in the drivers side and vise versa.
Anyway, I was able to find a fuse spot to plug in the harness, and everything works. Longterm it's not ideal, as the wire is running across the battery.
My question is can I splice a longer piece of wire onto the harness to give me more room and tap into the correct fuse #52? ( I currently am plugged into the Hitch light, which I don't have, so it worked out.) I am getting some heat shrink tubing to splice in the blinkers, so if I can buy some extra wire,. Additionally, am I correct that I need to buy 20g wire??
See pic attached as how the harness is running, I really don't like it this way.
Jeep Wrangler JL Need some assistance after Installing LED headlights. PXL_20240830_225241692
Jeeplover278
Jeeplover278
Peg
2021 Wrangler
Yes, just match the wiring and use heat shrink butt connectors.
Thanks, I got the wire and heat shrink tubing and got it completed, much better. I had to use another 20A fuse location since the harness was backward, the plug with the fuses wouldn't fit in that spot.
