Need help with where this plug goes
Bugdude
El Paso, TX
2025 jl
2025 jl
I found this plug on the ground just behind the driver's side front tire, I can not figure where it goes.
Can someone help?
Jeep Wrangler JL Need help with where this plug goes 1000000786
Jeep Wrangler JL Need help with where this plug goes 1000000787
Terrymo
Terry
2023 JLURXR 3.6 ET
There’s a plug in the firewall where the clutch pedal would be if you have an automatic. People use that plug to route wires from the engine compartment into the cab. At least that’s what mine looks like. Look below your brake booster in the engine compartment for a hole
Ormond Beach, Florida
Retired at 55 ..
@Bugdude
@Terrymo 's info is correct.
IF you have an automatic tranny JL, you will find the removable plug on the driver's side firewall.
On the inside of the JL it is right where the clutch pedal hardware would come through.
The part number for this plug is 68336758AC PLUG-DASH.
Place the cap in the hole & rotate the cap a bit from the engine compartment side (driver's side of the JL) to secure it.
You can use a dab of silicone on the threads to help secure it to the firewall... so it does not rotate and fall off again.
Jeep Wrangler JL Need help with where this plug goes 439248-b9926fbe49c21e6485285871e9ad9f37
SadRobot
Los Angeles
2025 Prius LE
Ah the infamous driver side firewall plug. Well now I finally know what that looks like.
Bugdude
El Paso, TX
2025 jl
Thanks!
Found it, just to the outboard side of the brake booster.
wanderer
Ralph
Carlsbad CA
Engineering Geologist
excellent thanks everyone
