My new wiper arm puller tool
LuvHydro
Midwest
21 JLUS Hella , 22 JLUSS Hydro
If you have attempted to remove your wiper arms, you probably noticed they are on tight. Some info below on the wiper arm/battery post puller I got for 11 bucks, shipped.
There appear to be two similar versions on Amazon. Be sure you get the new one with the beefier screw to prevent handle failure.
I was surprised with the weight of the unit. Probably 3x heavier than I expected at nearly 12oz.
Jeep Wrangler JL My new wiper arm puller tool 20220826_195510
It was reasonably priced, is simple to operate, fits fine & works perfect.
Jeep Wrangler JL My new wiper arm puller tool 20220827_123942
I know from a previous post, some feel lowering the windshield to clean it is a waste of time. I respect your opinion. If you are in that camp, disregard the balance of my post.
I am a bit anal on my windshield being clean for safety reasons. I find lowering it is quick & simple & allows for an extremely easy triple cleaning, leaving the entire inner surface swear & haze free.
You first remove the wiper arms. Pop off the plastic decorative caps, remove the two retainer nuts & pop the arms off & attach the puller.
Jeep Wrangler JL My new wiper arm puller tool 20220827_122947
There are only 4 screws that need to be removed to drop the windshield. They are T40s (highlighted in photo). I use the toolkits T40 bit in a cordless drill to speed the removal process & drop the winddshield.
Jeep Wrangler JL My new wiper arm puller tool 20220827_121856
Jeep Wrangler JL My new wiper arm puller tool 20220827_122254
Realistically you can do all this in just a couple minutes.
You can then take your time to properly clean the interior of the windshield. Mine acquires the "new vehicle" film every couple weeks from the interior plasticizers outgassing.
It also gives you full access to really clean the dash, duck storage pockets & air louvers.
As mentioned in a previous post I use the Sprayway brand of foaming glass cleaner, which is ammonia free.
Jeep Wrangler JL My new wiper arm puller tool 20220827_121718
It feels good driving with a crystal clear windshield. ?
elf883
steven
NY
2024 jlu willys anvil
stationary engineer
thats nice ,
i just printed a puller and it works great !!!!! - now i need to print some sort of handle for the nut to make my life easier , maybe just a simple knob to fit over the nut
Jeep Wrangler JL My new wiper arm puller tool IMG_5859
Jeep Wrangler JL My new wiper arm puller tool IMG_5858
Jeep Wrangler JL My new wiper arm puller tool IMG_5857
Jeep Wrangler JL My new wiper arm puller tool IMG_5856
smokeythecat
2021 Willys Sport 2-door, 2019 Mini Cooper S
I discovered that the hold down clamps for machining v-blocks also work.
elf883
steven
NY
stationary engineer
ok, so i made/printed a fast knob for top of nut with some knurlys, soooooo much better
i just need to machine the tip of the bolt to a point to make it sit nice on the wiper stub
Jeep Wrangler JL My new wiper arm puller tool image2
Jeep Wrangler JL My new wiper arm puller tool image0
21 Willys
Shoals Junction, SC
2021 JL Willys Sarge Green
Nice setup you have. If the knurling gets too tough on your fingers, you can drill a hole horizontally through the head of your bolt and put a long roll pin in it (that would make it similar to the store bought version.) I have done this on several of my little jigs.
elf883
steven
NY
stationary engineer
Nice setup you have. If the knurling gets too tough on your fingers, you can drill a hole horizontally through the head of your bolt and put a long roll pin in it (that would make it similar to the store bought version.) I have done this on several of my jigs.
thanks for the tip - i will see how this works out , its not that rough of a knurl , but i will keep your idea in mind !!!!
@jaymz i can also wiggle mine to come off but i dont like to stress the stud anymore then need be, iv broken 2 with my other jeeps iv had doing it that way . the tool makes it slide off nice and smooth
Ed Pursell
-Ed-
Lehigh Valley Pa, Allentown
2021 JL Willys- 3.6 Pentastar,8 speed Auto, Selec-Trac transfer case
Supervisor- MRO Buyer Maintenance- Pet food Mfg.-Now Retired.
Just an fyi, Sprayway is an awesome cleaner, using this for years. Just for normal glass cleaning, not just for our Wrangler windshields. It’s a good product, doors, house windows, etc.
Ormond Beach, Florida
Retired at 55 ..
I've had the opportunity to look over and use this wiper arm puller that @elf883 has 3D printed/has come up with.
Can tell you his 3D printed tool is real nice. Terrific print job!
The knurly knob on it is real nice.
Very good wiper arm puller that now is in my bag of tricks so to speak.
Jeep Wrangler JL My new wiper arm puller tool yuio
MesaAZGuy
Simon
Mesa, AZ
2023 Rubicon XR 3.6
Electrical Contractor
I put in the performance wiper blades with the multi squirters on last night. I paid $112 at my dealer and they had it the next day. Thought I could pull the arms off by hand but no luck. Found an old cheap battery terminal puller that began to bend just before the wiper arm popped loose. I had ordered the Lisle wiper arm puller last night before I even saw this thread for future use. The 3D Printed one looks great.
Jeep Wrangler JL My new wiper arm puller tool IMG_2429
Jeep Wrangler JL My new wiper arm puller tool IMG_2430
