Keiland
Thought I'd throw my 1.5 cents in for the record in case anyone runs into same. Daughter #2 (19) ran down the battery parked in the DQ parking lot w lights on and radio on, then needed a jump (kids!
). Since then, slightly sluggish cranking & ESS Stop/start stopped working ("battery protection mode"). Volts reading a constant 14.3-14.4 while driving. After reading bunch o' threads here I figured it was the Aux battery but went ahead & bought an Interstate aux & main battery as the JL is 4 years old (w 40k otherwise problem-free miles). I started off removing fender & replacing the aux, which didn't change anything. Put in the new main battery, and all was fixed and working correctly.
I tested the old batteries After removing & the old aux was actually still decent reading 12.6, however old main read 11 .6v.
Only reason I post is the aux is frequently seen as the culprit w the ESS start/stop canary in the battery coal mine, but in this case, it was just the main battery causing that symptom. It's even possible the aux was compensating for the bad main? I probably could have figured that out by isolating and testing each beforehand, but figured was time for two new batteries anyways. Who knows how long the originals would've lasted had the "DQ incident" never occurred, but hey that's life! Hope this minor experience helps someone else who's stranded out there one day!
