Mopar soft top twill.. Heeelp
Italy
Jeep Wrangler jlu Rubicon 4xe
Hello everyone.. I just mounted the Soft top.. The rear side window corner doesn't engage Well.. You don't sleep as if it's a centimeter shorter... Could it be because it is new and has to be stretched??
6th Floor Mule
Keith
Woodstock, GA
2018 JLU Sahara 6MT
The corner should go in and engage securely before you stretch and attach the forward portion of the window. If the corner is popping out while you’re trying to attach the forward portion of the window, make sure both the top and bottom corners are secured correctly. You’re correct about the top being new and the “stretch,” so you may also want to grab an extra pair of hands to assist as well. Good luck!
frankie_rubicon
Italy
I'll do some pics about top and down engaging.. So you can see if it's correct!!
dsgrey
Kevin
2019 JLU
Picture of the top and bottom of the rear corner once you've attached the front tab?
