Mopar Simulated Rings
Newbomb
Adam
2021 JLU Sahara Altitude
Have you guys used anti-seize on the bolts for the mopar simulated beadlock rings?
RubyRecon
The OC
2020 Rubicon Recon
Yes I do. If not you will get corrosion between the wheel and bolt. I remove my rings about every 3 or 4 months to touch up and before I used antisieze I was seeing corrosion on the wheel threads. I also switch the rings to use the wheel as a true bead lock.
zouch
Berkeley, CA
XJ, JLUWD
no; the installation instructions don't call for anything on the threads.
using anything on the threads would require an adjustment for the torque specs that most of us haven't the wherewithall to calculate.
Grampas Toy
Stacy
Magnolia Texas
2021 Jeep Rubicon 392
Dumb question, and I'm too lazy to look it up but; what is the torque spec for the ring bolts?
Fly2crawl
Andrew
Orlando, FL
2025 Rubicon X manual trans
Airline Pilot
You are bolting steel bolts into an aluminum wheel in a wet, sometimes salty environment. If you don’t use anti-seize, the bolts will eventually seize in the wheels due to corrosion of dissimilar metals. If you unbolt them fairly often then not an issue but most people don’t.
X35
PA
2025 Wrangler Willys XR
Absolutely yes, I applied never seize liberally to all of my trim rings bolts.
Jeep Wrangler JL Mopar Simulated Rings IMG_1271
Jeep Wrangler JL Mopar Simulated Rings IMG_1727
